You are here: Home / Industry News / Nexen introduces compact precision ring-drive system
Nexen Group now sells a Compact Ring Drive (CRD) system with precision grade bearing and drive mechanism in a sealed housing. Freely programmable, the three-drive design configurations allow the CRD to be optimized for high speed, high torque or both, depending on the application.
With a 250 or 350 mm dial plate bolt circle diameter and a large open center, users can optimize performance in a small space. The combination of Nexen’s roller pinion technology with integrated bearing and motor/gearhead deliver a rigid, smooth system with zero backlash options from the motor through the driven load. The CRD is ideal for applications including cutting systems, gantry systems, medical products, robotics, aerospace, machine tool, semiconductor and material handling.Nexen CRD ring drive system
Benefits of Nexen’s Compact Precision Ring Drive System
• Indexing precision up to ± 30 ArcSec and repeatability up to ± 5.1 ArcSec
• Zero backlash options
• High output load capacity – up to 108kN
• Handles speeds up to 225 RPM
• Smooth in motion
As a leading manufacturer of precision motion control components, power transmission and web tension control products, Nexen works to remain at the forefront of cutting edge engineering and production excellence. Production capabilities include computerized control and testing systems, dry cutting applications, special coating processes, over 80 multi-axis precision CNC machine tools and automated assembly. For more information, please visit www.nexengroup.com or call 800-843-7445.
Filed Under: Industry News Tagged With: Nexen Group
