You are here: Home / Integrated Motion Systems / Grippers + End Effectors / SCHUNK PWG-plus two-finger angular gripper
SCHUNK-PWG-plus-two-finger-angular-gripperThe PWG-plus is compact and robust due to the oval piston drive, the strong aluminum housing, and the almost wear-free T-bar drive. Depending on the application, it can also be equipped with an ID/OD spring safety device. Numerous accessories are available, including inductive proximity sensors and magnetic sensors.
The PWG-plus gripper jaws and gripper mounting holes are capable of mounting directly to certain SCHUNK compensation units, attachment valves, and quick-change jaw systems.
There are many advantages to using the PWG-plus gripper, including the design of outrigger workpiece supports due to threaded connections and centering sleeve options. There are also a variety of gripper sizes and gripping torques.
SCHUNK is the worldwide competence leader for clamping technology and gripping systems. Totaling more than 60 years of experience, SCHUNK is a family owned operation and a global player in one. For more information, visit www.schunk.com
Filed Under: Grippers + End Effectors, Robotics Tagged With: SCHUNK
