You are here: Home / Industry News / Electric motor miniaturization, connectivity, and customization
Updated November 2019 ⚙️ Leading trends in electric motors for motion designs are migration to custom solutions; heightening emphasis on efficiency; and (where suitable) more use of motors that allow for miniaturization (with power-dense designs) and connectivity for IoT capabilities.
“As reshoring picks up steam, we see more mass-customization,” said Scott Evans, director of product strategy at Kollmorgen.
Today’s ventilators and heart valves must be indestructible and failure-free, so manufacturers of such devices must know their subcomponents will last millions of cycles in real-world use. That’s why BEI Kimco has a test station to substantiate the life of its linear voice-coil actuators (VCAs) for critical applications. Initial testing of two linear VCA families demonstrated the actuators work for more than 50 million life cycles, and continued testing verified actuators to 100 million life cycles; ongoing testing will see that number grow. VCA lifecycles are relevant to environmental stress testing, semiconductor, and automation uses as well.
Here’s a bit more to illustrate what that means: “Once developing countries started catching up with the ability to mass-produce with cheaper labor, manufacturing jobs disappeared from developed countries. But today, affordable automation and CAD/CAM now let companies bring manufacturing back to the U.S.,” Evans explained.
“There’s been proliferation of communication networks for sensors, VFDs, I/O, and servos, but industrial Ethernet offers the promise of simplification and cost control.” — Doug Parentice of Moog Animatics
It’s not just mass-produced cookie-cutter production this time around, but mass-customized products now possible with minimal changeover time for ever-smaller batches.
Some brush dc motors excel in medical applications needing quiet operation. DCmind Brush Motors from Crouzet Motors make just 35 dBA of sound.
“Even motion suppliers are figuring out how to customize quickly and efficiently, and at minimal cost. So OEMs that have an idea, but find that commercial off-the-shelf (COTS) motion products are insufficient, can now leverage co-engineering and customization with suppliers,” Evans concluded.
This is a Crouzet DCmind brushless motor with CANopen and integral control. It offers long life, ease of installation, and networkable operation for automatic doors on passenger-railway and subway cars.
Product consolidation electric motors
One permutation of the motor trend towards customization is product consolidation Share on X One permutation of the motor trend towards customization is product consolidation, according to Brandon Steinberg, regional business development manager of Portescap in North America. Here, motor manufacturers aim to meet customer demands for more speed, torque and integration with pre-integrated setups. “So for these engineers who want to boost speed and torque, we collaborate on designs that maximize the allotted space for high power output and efficiency,” Steinberg said.
Consider a related trend specific to brushless dc motors—integration of controls. A growing array of web-based configuration tools let designers pick such motor-control pairings more easily.
This Dunkermotoren BG 95 brushless dc motor outputs 1,100 W continuous power with an overload capability of up to four times that. Nominal voltages are as low as 24 Vdc, so the BG 95 is suitable for autonomous vehicles and other battery-powered applications. The motor can pair with planetary and worm gearboxes (up to ratio 710:1) and encoders and brakes specially designed to fit it.
More overlap between electric motor types
Integrated motion is a leading trend in stepper motors as well. Here, combining the stepper, drive, controller and encoder simplifies installation. In addition, control techniques such as hybrid Motion Technology (hMT) help stepper motors maintain their advantages of torque density, lack of jitter at standstill, and the ability to work without tuning, while delivering the reliable synchronization, torque control and cooler operation of servomotors. That’s according to Clark Hummel at Schneider Electric Motion.
Torque control for steppers (now possible with hMT) even lets steppers work on axes for winding, capping and clamping tasks once impossible because of stalling and loss of synchronization.
This is a 550-W Dunkermotoren BG 75 Direct Mains Connection (DMC) brushless dc motor. It’s representative of a larger trend towards integrated motor design, as it has integrated control electronics and (thanks to power-stage electronics) makes an external power supply unnecessary. It also contains PLC functions, fieldbus interfaces, and one of any number of encoders and brakes. 20 years ago, many of these components could’ve filled a control cabinet. Today, they all fit inside one motor housing. Depending on the application, this motor can even render a control cabinet unnecessary.
Other lines between which motor types are suitable for which applications are blurring. “Over the past decade, the use of variable-speed drives has dramatically increased for all applications,” said Will Delsman, inside and technical sales manager at NK Technologies. The company manufactures sensors to measure current, voltage and power for industrial automation machinery.
Implantable pumps treat many medical conditions. One is an active implant from Sequana Medical to address collections of fluid in the abdomen called ascites (by siphoning the fluid off and into the patient’s bladder). This ALFApump uses a maxon EC motor to drive the gear pump. The maxon EC 13 motor, tailored to implant requirements, has Hall sensors for position feedback to let a motor controller get reliable and stable operation—even at low speeds and high load torques.
More specifically, field-oriented sensorless vector-control-based drives have become commonplace, with both vector and voltage/hertz outputs available from the same drive. “Here, we see ac servos running positioning and product motion where only dc servos were used previously,” added Delsman.
Application-specific motors could reign supreme
Mass-customized motors often take the form of application-specific iterations. Here the catch is that motor designers must get as familiar as possible with end applications to help optimize performance, according to Matt Marrow, business development manager with Portescap. Only then can they tailor materials, magnets, construction and manufacturing processes to satisfy OEM specifications.
Medical devices are driving a trend toward components that are smaller, lighter and more efficient, such as this Moog P45 high-performance blower.
Case in point: Packaging and food and beverage demand cleanable motors, but legacy stainless-steel servomotors were expensive and big and often weren’t much more reliable than standard servomotors. Now, demand plus the Food Safety Modernization Act (FSMA) are forcing manufacturers to make these motors more durable.
Another example of function driving application-specific motor design is in the passenger railway and subway car market. This industry has historically used brush dc motors for automatic door actuation, but such motors failed and added complexity, due to the separate controls and associated wiring that had to run through the car, said John Morehead, national sales manager at Crouzet Motors and Crouzet Automation, brands of InnoVista Sensors.
“In response to the railway industry’s need for longer-life automatic door systems that are easier to install and control, Crouzet Motors developed DCmind brushless gearmotors with CANopen networking capability,” he said. “The gearmotors (because they’re brushless) last longer than the brush dc motors they replace, and (with integral controls) eliminate extra installation cost and complexity associated with brush dc motors and separate controls and wiring.” CANopen makes for economical and easy networking using a simple two-wire system.
Miniaturization is a motion trend of increasing importance in the medical industry. Here, Moog’s BSG23 series brushless dc motor delivers maximum efficiency from a compact design.
There’s yet another example from the medical-device industry. BEI Kimco linear-voice-coil actuators now have integrated position sensors. “We’ve developed housed linear actuators for ventilators and heart-valve life-test fixtures that survive more than 100 million cycles,” said Jim McNamara, BEI Kimco senior applications engineer.
Just 10 years ago, we started manufacturing housed actuators. “Now, our housed actuators provide reliability that our customers need and would’ve had to develop on their own,” he added.
Affordability in motors and control electronics
Others acknowledge specific examples, but say the move to motor-feature integration is a pan-industry trend. “Decreasing cost with increased subcomponents and electronics integration is driving motion-component innovation more than the demands of any single industry,” said David Marks, motor engineering and research manager at Moog Components Group.
In fractional-horsepower motors, Ed Tullar, sales manager at Groschopp, sees the increasing affordability of controls, electronics and sensors driving demand. Falling prices of rare-earth elements have also made the manufacture of myriad power-dense motors once again price-competitive.
On another front, Moore’s Law has enabled many applications that were unaffordable 10 years ago, as new controls now let engineers use traditional motor and power-transmission technologies for ever-more-sophisticated motion designs.
There’s a trend toward more connectivity for IoT capabilities. The Moog Animatics SmartMotor allows communication over Ethernet/IP.
“Motion control has so improved that error—actual motion versus commanded motion—is now controllable to the 1-µsec range by electronics mounted on or a few meters from the motion,” said Evans. “So, phenomena such as jitter and lag that were huge issues a few years ago are less significant issues now.”
Consider drive-by-wire designs.
“We can fly drones over targets of interest from one control center thousands of miles away using cable-TV satellites and COTS consumer electronics at both ends of the communiqué, and lag is less than a second. All of this was impossible 10 years ago,” said Evans. In fact, the same technologies now go into everything from multi-plant processes, such as refining to driverless vehicles for mining and other exploration tasks.
“Even ultra-simple applications, such as slow labeling machines, can have far simpler mechanicals because higher-performance motion is now more affordable,” continued Evans. “So if an OEM can buy a stepper system for the same price he once paid for a mechanical clutch, for example—well, why wouldn’t he do that?”
That’s especially true when end users of such a machine expect accurate label placement and zero scrap, and longer machine life by virtue of fewer wear components, but don’t want to pay more for the new version of the machine.
Here’s a brushless dc motor, a Slotted Mini Motor from Portescap, to output high power from a small package.
Here’s the same brushless dc motor, a Slotted Mini Motor from Portescap, in an exploded view.
Related articles on trends in motor technology
Updated: Trends in electric motors Part I — Miniaturization, connectivity, and customization
Updated: Trends in electric motors Part II — Scott Evans of Kollmorgen sets record straight on motion design
Updated: Trends in electric motors Part III — Networking, IoT, and sensing takes motor-driven designs to new heights
Updated: Trends in electric motors Part IV — More on miniaturization and the special case of medical applications
Updated: Trends in electric motors Part V — Research laboratories drive technology convergence
Filed Under: AC Motors, Brushless Motors, DC Motors, Gearmotors, Industry News, Motors, Piezo Motors, Servo Motors, Stepper Motors Tagged With: Moog, Portescap
