ABM traction drive systems for electric vehicles are available as bevel gearboxes, helical gearboxes and hub wheel drives. All drive types have outstanding efficiencies and quietness. High static wheel loads are possible with compact design gearboxes. Typical applications include forklifts, pallet trucks and sweeper-scrubbers that need sophisticated drive technology with high output at low energy consumption. ABM motor and drive systems offer long life without unexpected down times, compact design, low maintenance and ease of integration into the vehicle.
ABM traction motors are available in outputs up to 16 kW (duty cycle S2-60 min) ABM induction and SINOCHRON® motors provide high-power density and outstanding reliability. ABM compact, modular bevel gearbox design provides maximum flexibility for easy adaptation to the requirement of the vehicle. Electrically steered modular units incorporate induction motors, manufactured for specific vehicle battery voltage and integrated holding brake with minimal torsional backlash.
Traction motors and steering motors and drives for electric vehicles — Custom @ABMDrivesInc designs Click To TweetModular designs make it possible to manufacture OEM drive units even in small and medium volumes. It also provides the possibility to offer different drive options to end-users, for example, fixed motors can be used for traction as well as steer function requiring minimal space allowing for compact vehicle designs. Motors are available with sensor bearings or coils and even the integration of customer-supplied sensors is possible.
The complete motor-brake-gearbox units are manufactured completely in-house, for vehicle OEM’s purchasing complete traction and steer units with matched components; this reduces engineering, interface work as well as significantly reduces assembly time. For more information, visit abm-drives.com or leave comments below.
ABM DRIVES INC. engineers and manufacturers high-performance motor, gearbox, brake and frequency inverter setups for machines, plants and mobile devices in hoisting technology, warehousing, material handling, electric vehicles, biomass heating systems, wind turbines and many other markets. Founded in 1927, the company belongs to the Senata Group with an annual turnover of nearly 400 million € and more than 2,000 employees. Approximately 300,000 drive units are produced annually. In-house manufacturing includes tool-and-die design, aluminum-casting foundry, CNC housing machining, manufacturer of shafts, cutting of gear teeth, motor development technology, assembly and final testing.
