You are here: Home / Controls / PLCs + PACs / AutomationDirect Productivity1000 PLC has expanded capabilities
The Productivity1000 Stackable Micro PLC provides communications, user-friendly programming, integrated data storage, and a full lineup of discrete, analog and specialty I/O modules in a super-compact size.
A new CPU, more power supplies, analog I/O modules and specialty high-speed I/O and PWM modules are now available for the P1000 PLC from AutomationDirect. The P1-550 CPU, priced at $203.00, adds a fifth communications port that supports remote I/O for 16 GS series VFDs and 4 ProtosX Modbus TCP field I/O couplers.
The P1-02AC Universal Power Supply ($50.00) provides isolated, 26 W power to the Productivity1000 system from an external 100 to 240 Vac or 125 Vdc source. This power supply will provide power for up to 15 expansion I/O modules for a combination of up to 240 hardware I/O points. Also, now available, the P1-01DC power supply provides 16W of power to support a CPU and up to eight expansion modules from an external 12-to-24 Vdc power source.
The P1-02HSC high-speed isolated sinking and sourcing input module ($65.00) provides two independent single-ended 5-24 Vdc inputs that accept up to 100kHz of pulse/direction and quadrature signals. The P1-04PWM Pulse Width Modulation module ($72.00) provides four channels of sinking or sourcing 0-20 kHz, 0-100% duty cycle outputs for use with the Productivity1000 system.
New analog modules support 8-channel inputs or outputs and a new 4-channel analog input module provides 16-bit resolution for mA and VDC signals. Starting at $33.50, I/O modules are auto-discovered and easily added or removed. QR (Quick Response) codes are printed on each module for latest specs and wiring.
For more information, visit www.automationdirect.com/P1000.
Filed Under: Controls, Featured, I/O, Industrial Automation, PLCs + PACs Tagged With: AutomationDirect
