You are here: Home / FAQs + basics / FAQ: When to pick ac gearmotors, and when to pick dc?
February 9, 2017 By Miles Budimir Leave a Comment
Gearmotors can be built around either an ac or dc electric motor. The choice of motor type depends on a number of factors.
In general, dc gearmotors, particularly brushless dc motors, have really good speed regulation properties, so they’re usually preferred in applications requiring tight variable speed control. However, over the years, ac gearmotors have gotten better at speed control, to the point where many are competitive with their dc counterparts.
Another factor is maintenance. Ac gearmotors generally require less maintenance and so are better for applications involving hard to reach areas or where environmental factors are more of a concern. By and large, most industrial gearmotors use ac motors, usually fixed-speed motors.
There’s also cost. Dc gearmotors are typically a bit more expensive than comparable ac gearmotors, due in large part to their speed regulation properties.
gearmotors
These right-angle ac gearmotors from Bison Gear use hypoid gearing and can be powered by either single phase or three-phase ac sources.
Filed Under: FAQs + basics
