You are here: Home / Controls / Part 4 of 4: EtherCAT and power, CANopen, and cybersecurity
In this four-part article series, we cover the fundamentals and new innovations related to EtherCAT. (Read the previous installment here.) In this final installment, we detail Power over EtherCAT and EtherCAT P, the CANopen over EtherCAT or CoE application profile, and EtherCAT’s compliance with the European Union’s Cyber Resilience Act. We also cover motion-control and other EtherCAT applications, emerging alternatives such as OPC UA FX and CAN XL, and functional safety with FailSafe over EtherCAT or FSoE.
M8x1 EtherCAT P connector image: CONEC
EUCHNER MGB2 multifunctional guard-locking systems with EtherCAT P/FSoE satisfy up to PL e with flexibility to adapt to reconfiguration.
In widespread use (especially to enable certain forms of distributed controls) is IEEE 802.3af/at/bt Power over Ethernet (PoE) technology. It’s most commonly used for IP cameras, wireless access points, VoIP phones, and modest motion-actuator applications. Source output is 44 to 57 Vdc and 0.35 to 0.96 A per pair. Power over EtherCAT includes a base sensor variant delivering 48 Vdc to 350 mA as well as EtherCAT P delivering dual 24 Vdc supplies to 3 A each … and high-power connector variants scaling to 850 Vdc or 630 Vac and to 72 A. That’s useful for distributed I/O, sensors, small drives, and actuators in compact machine cells.
Power over Ethernet delivers electrical power and data over standard Ethernet cable.
EtherCAT-ready automation components
Drives, controls, encoders, sensors, and integrated smart motors with EtherCAT connectivity abound and include stepper drives, VFDs, and servodrives integrated into multi-axis machinery needing command over position, velocity, torque, and more. For FSoE are EtherCAT I/O blocks, safety drives, switches, light curtains, and emergency stops.
Decentralized → centralized → cabinet-free: EtherCAT distributes the handling of frames, so one could say it’s a distributed solution … yet it’s billed as a centralized PC-based solution when contrasted with Ethernet-based protocols borne of early bus wiring and PLC-based control. Now things have come full circle and EtherCAT underpins various cabinet-free machine builds. Shown here is Beckhoff’s MX-System Designer — a web-based engineering tool that supports the planning and design of cabinet-free automation. Image: Beckhoff Automation
The CTED multi-protocol interface for VTUX supports direct connection to Industrial Ethernet networks including EtherNet/IP, EtherCAT, Modbus TCP, PROFIBUS, and CC-Link. Image: Festo
Kollmorgen’s P80360-ECE EtherCAT stepper drive provides realtime control of two-phase stepper motors with 3.0 Arms continuous and 4.2 A peak.
The Teknic ClearPath-EC integrated brushless servomotor integrates a conformance-tested EtherCAT vector servodrive and high-resolution encoder in one waterproof and dustproof housing.
POSITAL’s IXARC optical absolute rotary encoders provide resolution up to 16 bits (65,536 steps) per turn. The EtherCAT interface has been tested and certified by the ETG.
The CANopen EtherCAT Ethernet turducken
The OSI model’s application layer contains services and objects specifically written to trigger actual machine functions. Here, EtherCAT very often carries the CANopen over EtherCAT or CoE application profile — adopted by EtherCAT at its inception in 2003.
Why CAN? Well, many servodrives had firmware based on the CAN in Automation CiA 402 standard; many motion controllers relied on its software libraries to parse object dictionaries, interpret bits, and command transitions. CoE gave countless vendors an easy way to adopt EtherCAT.
CAN itself was released by Robert Bosch GmbH in 1986 to replace point-to-point automotive wiring — and was always an open standard to encourage adoption. It was also freely licensed to semiconductor manufacturers who then flooded the market with affordable CAN chips. Industrial engineers began repurposing these CAN chips for factory automation … prompting the formation of the CiA in 1992 to establish the CANopen standard. CAN also spurred the development of DeviceNet of Allen-Bradley (and later the ODVA). Today, CANopen is obviously still used in motion control as well as commercial vehicles, maritime vessels, medical equipment, public transportation systems, and elevators.
EtherCAT functions as an agnostic transport layer — most commonly carrying CANopen over EtherCAT or CoE. However, servo profile over EtherCAT or SoE maps the SERCOS information model onto EtherCAT frames so CNC builders can avoid rewriting legacy control logic. File access over EtherCAT or FoE handles firmware and configuration updates via a TFTP-style structure. Ethernet over EtherCAT or EoE tunnels standard IP traffic. ADS over EtherCAT or AoE facilitates diagnostics.
In short, EtherCAT uses CANopen’s logical architecture while discarding its physical limitations and bitwise bus arbitration.
Cybersecurity with EtherCAT
It was announced November 2025 that EtherCAT meets the requirements of the European Union’s Cyber Resilience Act or CRA Security Level 2 without modification. Extensions are being prepared for applications with higher security needs. Downward-compatible protocol extensions alongside a dedicated certification authority (CA) will help component suppliers provide authentication with their products. TÜV SÜD is working with the EtherCAT Technology Group on an assessment report.
Image: Adobe Stock
EtherCAT avoids trojan and virus malware exposure via IP at its subdevices so can be handled like a fieldbus at its extremities. Processing on the fly means any frames not native to EtherCAT are discarded. In addition, the master controller can deactivate unused device ports and detect newly inserted unauthorized devices.
To be sure, there have been application-layer attacks such as Stuxnet (targeting Siemens PLCs), TRITON (targeting Schneider Triconex controllers), and PIPEDREAM (targeting TCP and CIP communications as well as Omron drives over EtherCAT). However, these are extremely exotic. The first line of defense is protecting the EtherCAT main with enterprise-grade systems.
EtherCAT applications (including motion control)
EtherCAT leads in robotic surgery, semiconductor wafer processing, and aerospace test systems such as wind tunnels and rocket engine stands. Its distributed clocks synchronizes nodes to within nanoseconds for applications that must coordinate simultaneous readings or motions. Entertainment and theme park applications use EtherCAT to synchronize multi-axis animatronic motion to audio tracks with the hard realtime control needed to make complex movements fluid. Image: Valleyfair via KEB America
EtherCAT synchronization to well under 1 µsec makes it suitable for coordinating servoaxes, electronic camming, interpolation, and realtime feedback loops of conveyance and robotics. For the latter, seventh-axis systems integrate as just another synchronized axis. That’s useful for packaging and assembly machinery, semiconductor production, machine-tool tending, and converting equipment.
Large process images also accommodate closed-loop feedback from machine vision and LiDAR and can coordinate motion with non-motion machine tools — the deposition systems in additive manufacturing, for example. Determinism is maintained across hundreds of distributed I/O points.
In short, EtherCAT networks allow simultaneous handling of high-speed servodrives, remote I/O, functional safety, vision systems, condition monitoring, energy monitoring, and smart sensors. Cyclic mailbox communication allows on-the-fly parameter changes to setpoints without halting execution. Accommodation of acyclic communication allow the networking of many enterprise-level operations and IT-OT integration.
Realtime diagnostics and condition monitoring via EtherCAT leverage the subdevices for vibration, load, temperature, and other data without adding bus overhead or disrupting motion-control tasks.
EtherCAT vs. OPC UA FX and CANopen XL
CAN XL may be suitable for emerging AGV applications involving large data payloads.
New technologies are released to market all the time. Case in point: OPC UA Field eXchange or FX is an extension of OPC UA using TSN as its timing mechanism to bring deterministic controller-to-controller and controller-to-device communication into applications traditionally occupied by industrial Ethernet fieldbuses. The FX variation may create some competitive overlap with EtherCAT though for now the trend seems to be continued complementary deployment with EtherCAT handling deterministic machine-level control and OPC UA managing interoperability, analytics, digital twins, and cloud connectivity above.
Another newer standard (primarily for automotive and heavy machinery applications) is CAN XL for 20-Mbps speed and Ethernet tunneling as standardized under ISO 11898-1 using a shared bus architecture on which nodes compete for priority with payloads to 2,048 bytes per frame. In emerging AGV applications involving large data payloads but not synchronization, CAN XL may be more cost effective than EtherCAT … because its single twisted-pair wiring can handle both motor control and sensor data.
Networking industrial safety with EtherCAT
Here Chris Woller of Beckhoff explains FSoE watchdog timers, CRCs, controllers, packet routes, and I/Os for what functions much like point-to-point communication.
Traditional industrial safety to prevent hazards and safeguard both equipment and users employ so-called white-channel networks — dedicated and redundant wiring and componentry that add to machine-build cost and complexity. No wonder black-channel safety-networking approaches (including PROFIsafe and safety over EtherCAT) are seeing increased adoption. Here, machine-safety communications travel on the same wiring as regular acyclic and cyclic traffic using a safety protocol between the lower OSI layers and application layers.
NexCOBOT’s Mini-ITX safety control board (SCB 100) has I/Os and interfaces for robotic control and motion control systems. What’s more, the board complies with functional safety standards plus has safety I/O and extra EtherCAT subdevice ports. Motion-system (including robotic) safety control can be implemented with an SCB 100 to simply system architecture.
FailSafe over EtherCAT or FSoE is an IEC 61508-based protocol suitable for applications to SIL 3. Engineers can add functional safety to equipment with FSoE so light curtains, laser scanners, and discrete safety sensors and encoders sharing temperature, vibration, position, and speed data can inform commands that go directly to contactors, drive safe torque off or STO functions, and locks as well as those coming come via a safety controller. FSoE devices are commonly certified to SIL 3 and ISO 13849-1 PL e depending on the complete device and safety function.
Filed Under: Controls, Featured, Industrial Automation
