You are here: Home / FAQs + basics / What are photoelectric proximity sensors?
Proximity sensors are used to sense the presence of objects or materials across a broad range of industrial and manufacturing applications. Key to their operation is that they don’t require physical contact with the target or object being sensed. This is why they’re often called non-contact sensors.
One of the most common types of proximity sensor is the photoelectric sensor. These sensors detect objects directly in front of them by the detecting the sensor’s own transmitted light reflected back from an object’s surface. A common arrangement is that both the emitter and receiver are housed in the same unit, but not all photoelectric sensors are constructed this way.
sensor
An example of a reflective sensor with both the emitter and receiver in a single housing. (Image via Pepperl+Fuchs)
There are three basic configurations for photoelectric proximity sensors; reflective, through-beam, and proximity.
Reflective sensors – In this type of sensor, a beam of light is sent out from an emitter and is bounced off of a reflector back to a detector. When the light beam is able to reflect back, this registers as no object being present. The beam failing to reflect back means there is an obstruction, which registers as the presence of an object. These sensors are less accurate than other types, but they’re also easier to install and wire and typically cost less than through-beam sensors.
The diagram shows a typical through-beam photoelectric sensor setup with separate emitter and receiver components. A break in the light beam indicates the presence of an object. (Image via Omron Industrial Automation)
Through-beam sensors – In this type of setup, an emitter sends out a beam of light usually directly in the line-of-sight of the emitter to a receiver. When an object breaks this beam of light, it’s detected as a presence. This type of setup requires two components; an emitter and a separate detector, which makes it a bit more complex to install and wire. However, the advantage is that it’s the most accurate of the sensing methods with the longest sensing range.
Proximity (diffuse) sensor – Diffuse photoelectric sensors are similar in some respects to reflective sensors. This is because like reflective sensors they emit a light beam in the direction of the object to be detected. However, instead of a reflector used to bounce the light back to a detector, the object to be sensed functions as the reflector, bouncing some of the light back to be detected and register an object’s presence.
Filed Under: FAQs + basics Tagged With: sensors
