You are here: Home / Encoders / AutomationDirect adds more Koyo incremental and absolute encoders
October 5, 2017 By Miles Budimir Leave a Comment
AutomationDirect has expanded its Koyo encoder product line to include additional incremental encoder output options and higher resolutions for absolute encoders.
The TRD-S Series of 6-mm solid shaft and TRD-SH Series of 8-mm hollow shaft incremental encoders now have 5-12 Vdc open collector output versions in addition to the existing 12-24 Vdc open collector or 5 Vdc line driver output versions. These light-duty industrial grade incremental encoders have an IP40 environmental rating with resolutions available from 100 to 2,500 pulses/rev and up to a 200 kHz maximum response frequency. Koyo light-duty encoders start at $90.00 and are cost-effective for applications with light loads on the shaft and perfect for industrial environments with good mounting conditions and flexible shaft couplings.
encoders
TRD-NA Series medium-duty absolute encoders are now available in resolutions up to 2,048 pulses/rev. Starting at $271.00, these medium duty encoders feature a small 50-mm diameter body with 35-mm depth and have a splash proof IP65 protection rating. Koyo medium-duty absolute encoders are suitable for applications with moderate shaft loading and flexible shaft couplings and are used where position data must be retained through power cycles.
All encoders carry a 1-year warranty and have a 30-day money-back guarantee.
Learn more by visiting: www.automationdirect.com/encoders.
  • motor
    What are integrated motor-drive combinations?
  • Encoder resolution and accuracy: What’s the difference?
  • encoder speed
    How are encoders used for speed measurement?
  • encoder
    Encoder manufacturers offer more custom, flexible designs
Filed Under: Encoders, Featured Tagged With: AutomationDirect
