You are here: Home / Controls / High-performance sensorless control from maxon motor
Now, a new control option from maxon motor has compact wiring and slim design. Called the HPSC, this sensorless speed and torque control allows field-oriented control (FOC) of brushless motors. Such control is without sensors from full stop to full speed under load.
This HPSC uses a sophisticated signal-injection algorithm which precisely determines the rotor position for a smooth startup each and every time. The motor control’s key benefits include:
• Low noise and no vibrations
• Maximum power efficiency
• Robust and reliable
This system contains an HPSC module 24/5 … and the dimension and power range can be adapted if required. The firmware of the module may be customized for every drive system.
The HPSC is a custom-made solution that’s suitable for surgical systems, fluid-delivery systems, rehabilitation, and prosthetics. Contact maxon for more information at [email protected].
Filed Under: Controls, Stand-Alone Controllers Tagged With: maxonmotor
