You are here: Home / Featured / Motion trends third edition: Industrial clutch and brake technologies
Brakes and clutches all stop or hold or index axes on motion machinery, but they must execute those functions to application-specific parameters. Trends in this technology continue away from strictly stock parts.
Case in point: Tailored power-off brakes for production automation continue to proliferate with demand for holding functions. This is to complement the ever-increasing array of servomotor applications for robotics and factory automation as well as medical and food-processing applications.
When applied dynamically, a clutch engages with a relative difference between input and output speed. Dynamic clutches such as the two Carlyle Johnson EMA units (left) and smaller AHA unit (right) have a speed differential that is greater than zero, so the engineer must determine required dynamic torque to properly size them.
Where such motors control axes, there’s need for brakes in case power loss (intentionally or accidentally) and the motor can’t hold the load in place. Here, holding brakes have either a permanent magnet or a series of springs that actuate to stop the motor shaft from moving. Consider one example — a specialty hybrid metric-imperial holding brake from Mach III Clutch. The metric input of this fail-safe spring-applied brake connects directly to a Japanese-made servomotor … and the imperial output side connects to a U.S. gearbox.
No matter the application, clutch and brake specification must be simple. “Especially when engineers are building prototypes or proof-of-concept mechanisms and machines, we also find they need application assistance and hardware quite quickly,” said Rocco Dragone, senior sales and application engineer at SEPAC.
This custom Mach III stainless spider-coupling clutch was developed for a food-processing equipment OEM. It’s sealed to withstand washdown and provides 5,000 lb-in. of torque.
Other agree. “Customized brakes and clutches have always been Mach III’s concentration,” said Lesli Riehemann, president at Mach III. “But for the past several decades, 75 to 80% of our annual production has been non-catalog products. In the past, not many manufacturers were interested in this niche … but times have changed, and now there is much more competition. This has been a positive for Mach III, because customization has become normalized.”
Hybrid holding brakes from Mach III have a metric input side that connects to a Japanese-made servomotor and an imperial output that connects to a U.S. gearbox. This one has a 2,400 lb-in. torque capacity.
Riehemann posits that the mere mention of the word custom once triggered an avoidance reaction in design engineers due to the association with budget-breaking cost and project crippling lead times. “Now, engineers no longer shy away, and we have many more opportunities to present customized solutions,” Riehemann noted.
Over the past couple of years, Mach III has added personnel to support its engineering department and improve workflows — so that documenting applications, producing custom designs, and estimating and generating quotations happens with accuracy and speed. “On the production side, we’ve also expanded our CNC department and invested in training to ensure our machinists can independently take any new component design from a slug of metal to a high-quality finished part … so we can maintain short lead times,” added Riehemann.
This Mach III torque limiter has Morse taper connections; it slips at 26 lb-in. to protect taps and reamers in an auto-assembly process from breakage.
Examples of recent custom designs from Mach III include a stainless spider-coupling clutch. Developed for a food-processing equipment OEM, the sealed clutch withstands washdown and installs quickly with an integral spider-coupling adapter. Another example is a torque limiter with Morse taper connections that slips to protect taps and reamers from breakage.
Again, though there’s been a decline in traditional clutch and brake applications, it’s been more than offset by (among other setups) demand for new brake and clutch options — including holding brakes to pair with smaller motors. This is forcing manufacturers to design and supply power-dense brakes, particularly for new industries in automation, medical, and aerospace.
“We’re filling our shelves to make some items available from stock — including standard spring-engaged brakes and permanent-magnet brakes … and we’re working to stock spring-engaged tooth brakes as well,” added Dragone of SEPAC.
Again, clutch and brake manufacturers’ integration support has meant internal changes. “We recently hired engineers to help with custom products, and we tell customers: Get us involved early in the design, at the concept stage,” said Dragone. The supplier also offers value-added product versions to reduce modest engineering efforts. Most OEMs are happy to pass design engineering to suppliers, Dragone added.
This is a SEPAC brake for a medical application.
In terms of markets driving clutch and brake design innovation, medical is a leader. “There’s been an explosion of medical companies designing surgery robots and associated equipment. In addition, medical applications need precision and performance … as the real promise of robotic surgery is that it’s more accurate than surgery by a human hand,” added Dragone. So here, SEPAC sees demand for accurate holding brakes with zero backlash. Ten years ago, designing a zero-backlash tooth device for these and other applications was impossible — but recent improvements in the accuracy of cutting tools and machines has made such brakes possible for some applications, said Dragone.
This is a brake with a splined hub. Image courtesy SEPAC
Filed Under: Brakes + Clutches, Featured, Industry News Tagged With: machIII, sepac
