You are here: Home / Featured / Top motion control stories of 2023
As in years past, the editors at Motion Control Tips have once again sifted through the data to see what stories our readers liked the most in 2023. Some of the most popular stories were ones that reported on automation and motion component trends, as well as stories on gearing and mechatronics.
Here are the top 5 stories we published in 2023 on Motion Control Tips.
#5 The latest developments in fast food automation
Fast-food restaurants across the globe are pondering ways to automate certain tasks or entire assembly lines to provide continuous service at low costs. They’re investigating new motion components, HMIs, and robotics for automated solutions to keep operations up and protect against future labor fluctuations.
Design World editors asked industry experts to weigh in on how robots, conveyors, linear actuators, and other motion components play a role in automated fast-food production.
timing belts
Food-grade and washdown high-performance timing belts are a growing application, as are ultra-high-performance, belt-driven linear drive systems. Image courtesy of BRECOflex.
#4 Five applications where smart mechatronics make sense
Smart mechatronics technology is being applied in a variety of industries, where the benefits include increased efficiency, improved accuracy, and enhanced productivity.
This technology has proven to be effective in improving the efficiency and effectiveness of many industrial processes. This article takes a look at five applications where smart mechatronics make sense.
motion control
Sensor-based compensation units, like the Smart Flex Effector from Bosch Rexroth, are used in wafer production in the semiconductor industry. They ensure accuracy of linear motion devices with high-resolution sensors, which are then translated into active correction movements. (Image via Bosch Rexroth)
#3 Encoder, sensor, and feedback trends
Earlier this year, a number of encoder, sensor, and feedback industry experts answered several questions about trends they are seeing with these components and the industry more generally. This article summarizes what they had to say.
encoders
Encoders such as the Dynapar HS35iQ offer visual indication of specific fault conditions to reduce troubleshooting time.
#2 How to get zero backlash out of gearing?
The kind of gears used in gearmotors have an impact on the available torque, but also on things like noise levels and accuracy. In fact, one of the more common sources of inaccuracy in gearmotors is due to gear backlash. So reducing the amount of backlash will lead to a more accurate gearmotor.
gearing
These zero backlash gear units from Harmonic Drive LLC consist of a zero-backlash gear integrated with a housing and precision output bearing. Motor mounting adapters let them connect to a designer’s choice of motor.
#1 Comparing stepper and brushless dc motors
For engineers and designers working on modern-day motion and other industrial applications, it’s vital to understand the advantages and disadvantages of stepper and brushless dc (BLDC) motors. This article looks at a widely used hybrid stepper motor and a 3-phase BLDC motor and compare both devices. It consider the working principles of these motors (physical size and power density) and make observations about the acceleration and noise aspects of each motor. Experiments performed under various load conditions reveal changes in power, efficiency, and temperature.
stepper motors
The key dimensions of the EZmotion MMS742038-24-R1-1 BLDC motor and a general-purpose stepper motor used in the test setup are shown here.
Filed Under: Encoders, Featured, Gears + Gearing, Industrial Automation, Motors Tagged With: Bosch Rexroth
