Miki Pulley’s CSZ electromagnetic clutches have a zero backlash design and provide an efficient connection between a motor and a load with low inertia, minimal drag and zero backlash.
CSZ clutches function using the magnetic force generated by the energized coil providing engagement of input and output members of the clutch. They feature an integrated bearing design making mounting fast and easy while ensuring application concentricity and excellent system runout. CSZ clutches operate well in temperatures from +14 to +104 °F (-10 to +40 °C).
Available in bores ranging from 10 to 15 mm, with brake torques ranging from 1.77 to 7.376 ft lb (2.4 to 10 Nm), the CSZ uses corrosion-resistant materials, and is RoHS compliant like all other Miki products.
“Miki Pulley’s CSZ clutches are a great choice for high performance printing, paper processing, packaging, food processing and textile manufacturing systems,” reports Jon Davidson, Miki Pulley sales specialist. “They are proven performers in system applications around the world.”
For more information about Miki Pulley CSZ clutches, visit www.mikipulley-us.com.
